Subject Topic: Boat Fridge_1981 245SRV Post ReplyPost New Topic
BostonCM
Posted: September 13 2006 at 15:26 | IP Logged Quote BostonCM
I have the original fridge in my boat. It works fine when hooked up to
shore power, but when I try to turn it on off of DC it won't kick on. I
have turned the fridge off before/after I turned the shore power off with
the same results. I checked, its hooked up to the batteries and the fuse
inline is good. Is there any where else where it can be bad? Ant help
would be appreciated. CM
BostonCM
Back to Top Printable version View BostonCM's Profile Search for other posts by BostonCM
CAP10PAT
Posted: October 02 2006 at 22:03 | IP Logged Quote CAP10PAT
See if you can check and measure the power at the fridge of your 12v wires. Make sure you have power there. You may have corroded contacts someplace - maybe in the inline fuse holder.
Back to Top Printable version View CAP10PAT's Profile Search for other posts by CAP10PAT
This page was generated in 1.2813 seconds.
