Subject Topic: -Winterizing Post ReplyPost New Topic
kromp
Posted: September 11 2006 at 19:49 | IP Logged Quote kromp
Hello,
I have a 1984 Sea Ray 270 Sundancer with twin 305 V-8's. Mercruiser Alpha 1's. I am in the process of winterizing the boat and am looking at one of the do-it-yourself kits. Has anyone used the kits with the ear-muff attachment that connects to the 5 gallon jug full of antifreeze? Any problems? Recommend it or not?
Thanks,
Kromp
Back to Top Printable version View kromp's Profile Search for other posts by kromp
kromp
Posted: September 12 2006 at 17:25 | IP Logged Quote kromp
Well, I went to West Marine today, and the salesman there sold me on the do-it-yourself kit. It took 10 gallons of antifreeze. One can of fogging oil.
Just warmed up the engine using water until the thermostat opened, about 15 minutes. Turned off the water, switched to the jug of antifreeze. Ran the engine until there was about 1 gallon of antifreeze left in the jug. Fogged the engine until it stalled. No problems. Done with -60 antifreeze. Same procedure for each engine. Ready for shrinkwrap.
FYI, the West guy told me to NOT let the antifreeze run out, hence the fogging while there was still 1 gal, in the jug. He said the antifreeze in the pump housing will protect the impellor and housing from freezing.
kromp
This page was generated in 1.2188 seconds.
