Last Post By: Trawler
Posted: Yesterday at: 11:56
Grady-White
 BoatUS Boat Groups/Manufacturer Forums>>Grady-White
Subject Topic: Grady-White gas tanks and ethanol Post ReplyPost New Topic
Rob Ransone
Posted: September 08 2006 at 09:21 | IP Logged Quote Rob Ransone
I have a 1992 G-W Gulfstream 23. Concerned about reports of ethanol gas and fiberglas gas tanks, I contacted the nearest G-W dealer. He informed me in no uncertain terms that: "Grady-White does not use fiberglas gas tanks!" And he also advised me to install a fuel/water separator filter, which I have done. He also advised me that there should be no problem with ethanol and my 2002 Honda 225 FourStroke engine.
Rob Ransone
Tidewater Virginia
Back to Top Printable version View Rob Ransone's Profile Search for other posts by Rob Ransone
Lady Bug
Posted: September 16 2006 at 18:38 | IP Logged Quote Lady Bug
You were informed correctly. Grady doesn't use fiberglass tanks.
I found myself with water in my tanks that got there when whoever was attempting to syphon gas this past winter (unsuccessfully) left the filler caps off when their deed was done. I noticed the situation but only after significant rain had fallen. The boat yard swore to me that they checked the bottoms of both tanks in my 1997 Voyager 248 and found no water. When my main tank got down to about 1/8 full I switched to the Aux. It took about 5 minutes for both Yamaha 150 (2 stroke) engines to sputter and stop. We were able to get them  going again by draining the water separators. We repeated this process three times before all trace of water was gone. The moral is: Those water seaparators are effective!
Back to Top Printable version View Lady Bug's Profile Search for other posts by Lady Bug
Ray from Ohio
Posted: September 16 2006 at 19:26 | IP Logged Quote Ray from Ohio
Do you know if this applies to all Grady White years?  We have a 1986 22ft Seafarer I/O.  Did they ever use fiberglass?
Back to Top Printable version View Ray from Ohio's Profile Search for other posts by Ray from Ohio
Lady Bug
Posted: September 19 2006 at 14:38 | IP Logged Quote Lady Bug
Don't know, but its easy enough to check. Take off one or both of the deck access plates and look at the tanks.
pescadero
Posted: October 05 2006 at 18:14 | IP Logged Quote pescadero
This message is for Ron Ransone and the responders to his original question about fuel tanks and ethanol.  As was reported by the responders, the Grady fuel tanks are aluminum and ethanol poses no problem.  For Ladybug, the fuel fills on Grady-White boats are made by Perko.  The March 2006 Anchorline (GW's newsletter) listed new locking devices by Perko to insert into the existing ones.  I put one on each of my two fuel fills.  I purchased mine through West Marine.  They are about $20.00 each.  At the price of gas, good insurance.
        Dave
Back to Top Printable version View pescadero's Profile Search for other posts by pescadero
Lady Bug
Posted: October 07 2006 at 12:53 | IP Logged Quote Lady Bug
Thanks Dave. I too saw that article and I purchased the Perko locking devices. I installed them this week. They look to be effective to prevent theft, but will not do anything to prevent rain water from getting into the tank if the thieves leave the caps off as they did last winter. I would have preferred locking caps, but every little bit helps, I guess.
RI Popper
Posted: August 25 2007 at 10:02 | IP Logged Quote RI Popper
I have an 83 gulfstream and it has aluminum tank. Infact I just had to replace it because it pitted through.
Armand
www.atlanticoffshorelures.com
Back to Top Printable version View RI Popper's Profile Search for other posts by RI Popper
ewkearns
Posted: August 25 2007 at 13:17 | IP Logged Quote ewkearns
Which one... main or auxiliary? Where did you have it made?
Back to Top Printable version View ewkearns's Profile Search for other posts by ewkearns
RI Popper
Posted: August 25 2007 at 13:31 | IP Logged Quote RI Popper
I had it made through http://www.custommarinefueltanks.com/ It is the only tank in that model It was a 65 gallon tank. They upgraded it to about 70 gallons and I still had room to spare.
Armand
ewkearns
Posted: August 25 2007 at 20:06 | IP Logged Quote ewkearns
WOW! I have an '87 Gulfstream and it carries 200 gallons. Roughly 100 in the aux and 100 in the main.
RI Popper
Posted: August 25 2007 at 20:40 | IP Logged Quote RI Popper
In retrospect I wish I had gone larger with that tank and anyway I can alwayse fit another tank where the inboard motor was.
Armand
ewkearns
Posted: August 26 2007 at 13:31 | IP Logged Quote ewkearns
YMMV, but my original documentation from G-W advised against putting anything like gasoline or a battery in that area.
My auxiliary tank is under the deck plate just aft of the cuddy door.. that might be a better choice for you. Certainly, it would help balance the load. IF your hull is like mine, you have room for 100 gallons there. IIRC the tank is about 28" deep with a "V" shaped bottom.
RI Popper
Posted: August 26 2007 at 14:09 | IP Logged Quote RI Popper
That is where my 70 gallons is now. And that pretty much takes up the space it's only a "205" which is less than 21' boat.
ewkearns
Posted: August 26 2007 at 15:42 | IP Logged Quote ewkearns
Ah..... OK...... Sorry, I went a little brain dead, there, and forgot that '87 was the first year of the 232G.
RI Popper
Posted: August 26 2007 at 18:06 | IP Logged Quote RI Popper
NP, I wish I had a bigger boat :)  but the bigger the boat the more gas you burn right?LOL.
I'm still hoping they come out with a diesle out-board.
Armand
ewkearns
Posted: August 28 2007 at 19:41 | IP Logged Quote ewkearns
I remember diesel outboards from 40 years ago. Problem was that they didn't have a lot of power and they weighed about a million pounds. I think Yanmar is still making one.
I've got two 140hp Suzuki 4-strokes on my Grady and have been very happy with their thriftiness, though I think I gave up some speed from the 150hp Yamahas. Oh well, boating where I do, there aren't many days that WOT is an option.... unless you want your kidneys in your hip pocket!
RI Popper
Posted: August 28 2007 at 21:37 | IP Logged Quote RI Popper
[QUOTE=ewkearns]I remember diesel outboards from 40 years ago. Problem was that they didn't have a lot of power and they weighed about a million pounds. I think Yanmar is still making one.
[/QUOTE
I would hope with today's high tech alloy's and composites an economic weight and price diesel could be produced in an outboard. Maybe I'm dreaming.  I know what you mean about being able to travel WOT. Don't get to do that much but I can cruise comfortable at 27 mph at 4000 rpms.
Armand
This page was generated in 1.8594 seconds.
