| Posted: September 25 2006 at 17:37 | IP Logged
Do not get caught putting WD 40 on your engines, if outboard or inboard, inboard ends up in the bilge and then overboard via the bilge pump, or drain out.
WD 40 is a pollutent, and EPA is hitting hard on oil pollution on the water ways.
WD 40 is a petro base liquid
If marina see it or finds out, you will be not be allowed to launch.
Fines are big $$$$.
As far as RPM to plane speed, add a good set of trim tabs, Bennett is at the top of list, they stand behind their product. My pump went south. it was 3.5 years old and the replace it a $0.0 cost to me, including shipping.
Just a suggestion.
Good luck
Craig
__________________ Gone a fishing
