Subject Topic: Window Leaks (Corinthian) Post ReplyPost New Topic
wakeme
Posted: September 06 2006 at 12:09 | IP Logged Quote wakeme
Have a 1985 38' Corinthian, and experiencing leaks in the aft cabin (port & stbd) windows.  Has anyone undertaken this task of repairing these leaks....removing entire window and re-sealing? OR any other tricks that I may use before doing something drastic?
Bob
Back to Top Printable version View wakeme's Profile Search for other posts by wakeme
Dlavington
Posted: September 06 2006 at 17:25 | IP Logged Quote Dlavington
I have a 29 ft Catalina with leaks that I suspect came from the fixed windows on the cabin front.  Rather than remove/reseal them (1986 model) I just had a pair of canvas snap-on covers made and installed.  I no longer have leaks (that I know of).
     Don't know if that would work on sliding windows, but if these are the fixed aft windows on the master stateroom you might consider it.  Good luck.  Dave
HIGH HOPES, 1985 ChrisCraft Catalina, 29 ft fb cruiser
Back to Top Printable version View Dlavington's Profile Search for other posts by Dlavington
rivermanil
Posted: September 28 2006 at 22:01 | IP Logged Quote rivermanil
I'd suggest one of the adhesive drip edges over the entire aft area
cockpit over the door and window, all the rain runs down that back.
The drip edge takes it off to both sides. No leaks on my 1980. Like
you heard earlier keep the water away is part of the battle. This fix
will not stop existing leaks tho.
For any other Corinthian owners, I could use a manual - anyone have
a copy to offer?
Riverman
Back to Top Printable version View rivermanil's Profile Search for other posts by rivermanil
wakeme
Posted: October 02 2006 at 08:27 | IP Logged Quote wakeme
Thanks for the replies...Like the idea of a "drip gutter", can only help. I have taken the STB window out, and recaulked and reset which has seemed to solve the problem. Had a dry weekend during a storm!
I too would love to get my hands on a manual!
Dlavington
Posted: October 05 2006 at 11:15 | IP Logged Quote Dlavington
When I bought my 1985/86 29 ft Catalina last year it came with an owner's manual, which I'd be glad to share with anyone; it isn't much help though.
the manual is 48 pages, 8.5x11, with a red cover.  It is generic, for all Chris Crafts, and has no specific information in it about any model....more like a textbook, or an introduction to powerboating.
the cover says it was "reprinted 7/82".  Here's a summary of the table of contents:
Introduction to your boat and boating
General familiarization
Maintenance
Useful information and record.
So, if you'd like, I'll mail it to you, relying on you to mail it back after you've made a copy.  I'll be glad to do the same for anyone else.
Dave Levington
Pete37
Posted: November 26 2006 at 20:07 | IP Logged Quote Pete37
To Wakeme:
Hi Bob,
Window leaks are generic to most boats because the construction of sliding windows is the same in nearly all boats.  Basically, at the bottom of the window opening, an open box, called a windowbox, is constructed out of wood.  This is true even in fiberglass boats.
The windowbox is on the inside of window opening and runs the length of the window.  It's top is even with the bottom of the window opening.  The top is open and the bottom of the window glass rests in an aluminum track on the botom of the box running fore and aft.  A second box at the top of the window has a second aluminum track which restrains the top of the window.  Usually two window panes, each with its own set of tracks, are incorporated in each box with one window sliding forward and the other aft.
In theory, rain hits the outside of window and runs down the window into the windowbox.  The windowbox is watertight so the water in the box is contained until the box fills and the water spills over the top of the box.  In order to prevent the windowbox from filling one or two holes are drilled in the outboard side of the box to allow the water to drain to the outside of the boat.
But after a few years debris accumulates in the box and plugs the holes.  At that point the box fills and you have what is known as a window leak.  The solution is to just hose out the debris in the box thereby opening the drain holes again.
This miraculously simple way to solve the problem works most of the time.  But many boat owners don't understand how a windowbox works and proceed to seal the window glass against the windowbox with various sealing compounds.  This eliminates the sliding feature of the window and also usually plugs the windowbox drain holes which leads to future leaks and rot.
In some cases, the windowboxes themselves rot and/or become leaky.  In these cases, the window panes must be carefully removed and the windowbox must be rebuilt or resealed.
But windowboxes remain leak free for a long time if their drain holes are kept free of debris.  Twenty years is not uncommon and most window leak problems are caused by plugged drain holes.  I've had boats with windowboxes for over thirty years and haven't had any window leak problems as long as I kept the drain holes open.
Incidentally, I too have one of those red Chris Craft Owner Manuals.  But you shouldn't expect much from it.  It is essentially useless.
Pete37
Edited by Pete37 on November 26 2006 at 20:26
INTERLUDE
leagle
Posted: February 24 2007 at 14:31 | IP Logged Quote leagle
I'm new to the forum.  A few months back a couple of you were looking for Corinthian manuals.  Still looking?  I have both the original operator manual, and the engine manual - the blue Chris Craft ones that came with the boat - for my '78 Corinthian.  If you still need them, I'd be happy to scan them to PDF, and email them.  I also have the boat's original blue prints.  A lot tougher to scan, but if someone needed a specific element of the boat design, I could try.
Mike
Back to Top Printable version View leagle's Profile Search for other posts by leagle
Dlavington
Posted: February 24 2007 at 19:01 | IP Logged Quote Dlavington
Dlavington
Posted: February 24 2007 at 19:04 | IP Logged Quote Dlavington
Mike, that's a generous offer.  It won't help me, with my 1985/86 Catalina, but it raises a subject where I could use help...does ANYONE have a wiring diagram for a 85 or 86 Catalina Flybridge, twin screw express?
Dave at High Hopes
wakeme
Posted: February 26 2007 at 09:58 | IP Logged Quote wakeme
I had found out that my "leaking" problems were more extensive than originally thought. The winter lay-up has been dedicated so far to solving these problems. I have removed the large aft window and re-bedded and sealed along with the aft starboard sliding window. Problem resolved here.  I also had leaks in the forward cabin, on both sides of the V-berth. Removed both portal windows, new gaskets, seals and rings (the windows were in excellent shape). Had to contract with the local boat builder to re-seal and tighten the deck-to-hull joint which was in bad shape. Also re-bed (8) stantions on the fore-deck. Will not know if this is resolved till "underway" in the spring. Appears to be dryer than Phoenix in the summer now!
My next projects are now delayed with a Broken Shoulder while slipping on the ice at home!
BluesBarge
Posted: February 26 2007 at 22:48 | IP Logged Quote BluesBarge
Window channels...
http://www.defender.com/productsearchresult.jsp
I have several to tear into soon...
Edited by BluesBarge on February 26 2007 at 22:50
M/V Fun Size
                 HADDONFIELD, NJ
Back to Top Printable version View BluesBarge's Profile Search for other posts by BluesBarge
sdunlap20690
Posted: June 26 2007 at 21:01 | IP Logged Quote sdunlap20690
Dave at High Hopes
Dave,
I have many of the wiring diagrams from Bellingham for my 1986 362.  Got the set from SEA CURE Technology.  They are Uniflite specialists but also have a lot of Chris Craft data and parts.  They built a bow pulpit for me "...probably from the mold for the original   ."  http://www.web4wise.com/seacure/ gets you to their website and parts catalog.  There is a link to an email for information.
Steve and Pat
Some Tuesday
1986 362
Tall Timbers MD
Back to Top Printable version View sdunlap20690's Profile Search for other posts by sdunlap20690
TBYS
Posted: September 11 2007 at 12:55 | IP Logged Quote TBYS
Quote: sdunlap20690
Dave at High Hopes
Dave,
We fix the boats
Back to Top Printable version View TBYS's Profile Search for other posts by TBYS
TBYS
Posted: September 11 2007 at 13:00 | IP Logged Quote TBYS
Consider yourself lucky. This is a 2005 Roamer 40 that the factory refused to repair under warranty. They say it only had a 1 year warranty. Over $40,000 to repair the damage.
I have many more pictures if anyone's interested.
TBYS
Edited by TBYS on September 11 2007 at 13:03
We fix the boats
Dlavington
Posted: September 11 2007 at 14:52 | IP Logged Quote Dlavington
Steve and Pat, thanks!  I've sent them an email, we'll see what happens.  Dave at HighHopes
This page was generated in 1.7500 seconds.
