| Author |
Lewis Culler "Seaman Recruit"
| Posted: September 04 2006 at 07:53 | IP Logged
I own a 1982 Chris Craft Corinthian and am thinking of moving it from the coast to an inland lake. Can this boat be moved without removing the flybridge? If not how hard is it to remove the flybridge?
Back to Top  |
Dlavington "Seaman Recruit"
| Posted: September 04 2006 at 15:29 | IP Logged
The boat can be moved okay, the problems comes with the highway. You should check with some guys who truck boats...your boatyard should be able to recommend someone..if not any broker will know some truckers. You/he will need a permit, since the Chris is over 8 ft wide, and will probably have to remove the flybridge in order to stay within the height limitations on your trip....cross-bridges, telephone wires, etc. Removing the bridge isn't difficult, but it takes some hours and some knowledge. Lots of things have to be disconnected and then put back together again properly. Good luck. Dave
__________________ HIGH HOPES, 1985 ChrisCraft Catalina, 29 ft fb cruiser
Back to Top  |
rivermanil "Seaman Recruit"
| Posted: September 28 2006 at 21:58 | IP Logged
Mine moved with dropping only the upper control station, bridge
stayed intact, but the Stainless rail tops also came off. Moved from
MN to IL.
__________________ Riverman
Back to Top  |
suwanneered "Deckhand"
| Posted: September 04 2008 at 21:43 | IP Logged
HI: You can probably get by without total removal of the fly bridge. Transporters can advise on the. I do know if it is over 13 foot high a front pole car escort is required and also a rear wide load escort.Getting it under 13 foot will save on the pole car escort.size and weight also come into play as to the routes,etc.I would call a transporter and get a estimate of the cost.
Back to Top  |
Brian2008 "Seaman Recruit"
| Posted: October 24 2008 at 06:38 | IP Logged
Chris Craft Corinthian- Commander 36
Great condition, many upgrades interior and exterior
New Hard Top in 2007
With new canvas enclosure
New Electronics box 2008
New engines aprox 2005
Double cabin with large Head with seperatte shower
New trim in interior & most all up graded aprox 2005
Fuel capacity, 400 Gal
Water cap. ===================================== Brian
Our mission is to provide high quality end to end solutions
to the BPO segment in a manner that will improve the operational efficiency
while reducing the cost of the services to the client.
4thdimension1@gmail.com
Back to Top  |
Capt. Heavy "First Mate"
| Posted: October 27 2008 at 08:47 | IP Logged
Hi guys. I just discoverd the corinthian forum. I have a 1977 331 corinthian flybridge. I moved her fom Maryland to STUART, FLORIDA 7 years ago. Hire a marine trucking outfit to mover. Had to lomwe the bridge cover,remove flybridge windshield and steeting wheel. Only problem when the boat arrived at riverwatch narina, I found out the truck had an air shoch blow out and a tire tried to eat a hole in bottom of my hull. Marina called in a glass tech who fixed it quickley , the trucker paid for it and we launched that evening. I've owned Mystic Diver II for almost 20 years. Owned a 25 chris catalina before that. Hope we can Have a good forum like the catalina guys. Capt. Heavy
__________________ Capt. Steve, Stuart Fl. Chris Craft Owner- 25 catalina, 331 corinthian. Licensed Capt. 20 Years, Certified diver for 30 years. Avid fisherman.
Back to Top  |
| Posted: October 28 2008 at 10:16 | IP Logged
Does anyone else out there have a 331 corinthian (coho)???Capt. Heavy
Back to Top  |
