Californian
 BoatUS Boat Groups/Manufacturer Forums>>Californian
Subject Topic: varnish Post ReplyPost New Topic
just in time
Posted: September 02 2006 at 11:52 | IP Logged Quote just in time
we bought a 34' californian 1982, and i'm learning how to strip and varnish the trim.
i'd like opinions on the method used to apply the first coat...my husband says 50% minerial spirits & 50% varnish on 1st coat of bare wood, then 1/3 & 2/3 parts on 2nd...
is this necessary?
just in time - gashouse cove, sf, ca
Back to Top Printable version View just in time's Profile Search for other posts by just in time
charlesm
Posted: December 02 2006 at 16:08 | IP Logged Quote charlesm
My wife and I also have a 34' 1982 Californian and I have tried three
finishes on the exterior teak- Epiphanes/ Cetol/ Minwax Helmsman
varnish- I find the Cetol the best/ most durable- when I used the
Epiphanes I did it per instructions- stopped at 6 coats (weather too cool)-
during the winter and spring of the next season it started to fail- I think
the teak is too oily---so I am going back to the Sikkens Cetol...
               Good luck-
                                              Charlie- "Somewhere"
Back to Top Printable version View charlesm's Profile Search for other posts by charlesm
Jspence
Posted: December 03 2006 at 18:06 | IP Logged Quote Jspence
I Have a 50' Californian, I refinished the teak toe rails, fly bridge doors and trim etc with Honey teak. It is a two part finish applied in 2 steps. First I applied 3 coats of "Honey", followed by 3 coats of clear. After that you scuff it with a scotch bright pad annually (or so) and apply another coat of clear. I finished almost 2 years ago and have not had time to put the annual coat on yet. Honestly it looks just like it did when I finished it almost 2 years ago. If you have any questions You can contact me for further information.
Good Luck    Jim
Back to Top Printable version View Jspence's Profile Search for other posts by Jspence Visit Jspence's Homepage
This page was generated in 0.8887 seconds.
