Subject Topic: Sea Ray 400DB Sedan Bridge Post ReplyPost New Topic
JABruno
Posted: September 01 2006 at 20:22 | IP Logged Quote JABruno
Hi, I just joined this forum and I'm recently bought a 2001 Sea Ray 400DB Sedan Bridge with Cummins 450 hp diesels. I had zero problems so far but my luck has got to run out sometime. Anyone with a similar Sea Ray, please let me know what I might expect down the road.
Back to Top Printable version View JABruno's Profile Search for other posts by JABruno
SRBCNC
Posted: September 05 2006 at 13:09 | IP Logged Quote SRBCNC
Hi,
I have a 1999 400DB with Caterpillars. Congratulations on acquiring a great Sea Ray. The best way to prevent problems is through regular maintenance. This is especially true with diesel engines. Your Cummins diesels should be serviced (oil, oil and fuel filters, etc.) at least once every 12 months depending on your useage. Batteries should be maintained with proper fluid levels and never be allowed to discharge more than 50%. External and internal zincs should be checked regularly for corrosion and replaced in necessary. The list goes on and on (see your Owner's manual).
Bruce Curley
SRBCNC
Back to Top Printable version View SRBCNC's Profile Search for other posts by SRBCNC
Margo's Deal
Posted: September 14 2006 at 15:47 | IP Logged Quote Margo's Deal
We have a '97 400DB with Caterpillars. Hope you enjoy you're boat as much as we do ours. My friend has a '99 41 Formula with the 450 Cummins you have. He has about 260 hours on the engines with no problems at all. He purchased the boat new.
PDG
Back to Top Printable version View Margo's Deal's Profile Search for other posts by Margo's Deal
