Subject Topic: Monticello Table Pull-out Extension Stuck Post ReplyPost New Topic
iduate
Posted: August 30 2006 at 15:11 | IP Logged Quote iduate
Hello,
Anyone know how to "unstick" the sliding pullout on the Pedestal table used for sleeper cushion?  There's no way, I've tried pulling shaking etc. that I can extend it out.
I have no idea how to access either, does anyone understand the jamming mechanism?
Regards,
Fermín
Back to Top Printable version View iduate's Profile Search for other posts by iduate
NHDoral
Posted: August 30 2006 at 19:09 | IP Logged Quote NHDoral
I have never seen it get stuck. However, I would think that it should still pull with the strap. Try pulling up and out, if you just pull out it will not unjamn. If that does not work try prying it out with a pinchbar. Be careful not to scratch the finish.
Cheers,
NHDORAL
Back to Top Printable version View NHDoral's Profile Search for other posts by NHDoral Visit NHDoral's Homepage
iduate
Posted: August 30 2006 at 20:26 | IP Logged Quote iduate
I spoke w/JC Demers @Doral.  He also had never seen this.  He checked w/technicians and plate slides on track and is held in place in the "in position" with two spring loaded ball bearings one on each side.  Its possible that the balls are dislodged and wedged thereby locking the plate.  Suggested remedy return to dealer under warrantee.
Regards,
Fermín
