Subject Topic: zincs Post ReplyPost New Topic
rsteinfeld
Posted: August 26 2006 at 10:53 | IP Logged Quote rsteinfeld
I am new to boating and have a 2004 Sundancer 340.  I've placed new zincs on her in May.  I have someone dive the bottom monthly and he has noticed that my prop zincs have completely eroded but the transom zinc is untouched.  Also he noticed a significant build up of barnacles and heavy growth around the trim tabs and upper part of the rudder only.  His feeling was that this could represent loss of electrical current from my boat or current from another source.  Does anyone out there have experience with this?
R Steinfeld
Vero Beach, FL
Back to Top Printable version View rsteinfeld's Profile Search for other posts by rsteinfeld
Bob Adriance
Posted: August 31 2006 at 10:36 | IP Logged Quote Bob Adriance
Do you keep your boat plugged into shore power?
Bob Adriance
Bob Adriance Editor, Seaworthy
Back to Top Printable version View Bob Adriance's Profile Search for other posts by Bob Adriance Visit Bob Adriance's Homepage
rsteinfeld
Posted: September 01 2006 at 11:55 | IP Logged Quote rsteinfeld
Yes I keep  it plugged into shore power.
R Steinfeld
Vero Beach, FL
Bob Adriance
Posted: September 05 2006 at 08:21 | IP Logged Quote Bob Adriance
See if this helps:
http://www.boatus.com/seaworthy/galvanic/default.asp
LOLA
Posted: September 09 2006 at 14:10 | IP Logged Quote LOLA
As your prop zinc deteorates faster than your transom zinc it indicates that the electrical connection between the transom zinc and engine block ( shaft ) is poor or broken. Normally a green wire connects all metal hull fittings together and to earth ground via your shore power cable. Check and clean all these connections. If you find your transom zinc begins to errode quickly after you have reestablished your grounds you my have a dock neghibor leaking current. I would suspect an old wood boat.
Trim tabs are not normally painted with antifouling paint and are generally cleaned monthly. Your rudder area may need paint. I'd wait untill the next haul out.
1979 Californian LRC and Sea Ray 215 '00 owner.
Back to Top Printable version View LOLA's Profile Search for other posts by LOLA
dau
Posted: December 13 2006 at 07:11 | IP Logged Quote dau
Also, make sure your anodes are the correct one's for salt water. I took delivery of a 2006 340 this summer and within 3 weeks of being in the water, mine were totally gone. Searay had the salt water one's on and I am in the great lakes, after the correct anodes were put on, no issues.
Edited by dau on December 13 2006 at 07:13
SeaBreeze,
2006 Searay 340 Sundancer
Buffalo, New York
Back to Top Printable version View dau's Profile Search for other posts by dau
